It is currently Fri Jul 04, 2025 12:06 pm
PostPosted: Sun Feb 22, 2009 8:47 pm
First name: Wolf
Last Name: Moehrle
City: Neustadt
Zip/Postal Code: N0G 2M0
I was planning on putting the finish on electric guitars and then installing the nut, but this would mean being very careful not to get any grain filler or clear coat in the nut slot. So now I’m thinking of installing the nut first, and then putting the finish on the instrument. I would leave the nut bigger and then file it down when I cut the string slots. This way the grain filler and clear coat would flow right up and around the nut sealing it in very nicely.
What do you think?
PostPosted: Sun Feb 22, 2009 8:53 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Masking tape covering the nut slot will keep it clean, and you will have an easier job removing the nut at a later date without finish on it.
Fred
Fred Tellier
PostPosted: Sun Feb 22, 2009 9:01 pm
First name: Stephen
Last Name: Ziegenfuss
City: Jackson
I agree with Fred. I would just tape off the nut slot and install it after the finish has been applied....But you can obviously save yourself some heartache if you fit the nut first, leaving it a couple thou' wide to account for the finish thickness.
Stephen
www.ziegenfussguitars.com
PostPosted: Sun Feb 22, 2009 9:20 pm
Stephen
Welcome home buddy! Got some girl scout cookies here for ya [:Y:]
PostPosted: Sun Feb 22, 2009 10:43 pm
You can just make the nut so it plays correctly, remove it and install a dummy nut (Hmmm sounds like someone I know). Then complete the finish, score accurately against the dummy with a sharp razor to remove it and then fit the nice clean nut already to go.
Hey look at that! I just made my 2000th post here talking about a dummy nut, bet no one has done that before :D
Users browsing this forum: Bing [Bot] and 8 guests
